Updated for 2020
Here is the new layout:
Again, slightly easier to see from the Stream Deck app than an actual photo:
Show Changes
I’ve added the three new shows which have started since I last did this:
Sadly, I removed my beloved Playing for Fun as it is now “retired”.
I also added Departures despite it not really being a show like the others. If Relay.fm adds a podcast without “retiring” one, Departures will be the first to go (which seems appropriate). Next would be B-Sides if they add two.
Important: I put “The Pen Addict” between “Parallel” and “Pictorial” rather than being listed under “T” because I’m not a monster.
Top-Left button
You’ll notice that the top-left corner is a “generic” Relay.FM logo. That’s actually a folder so if you press it, you will see 5 buttons, each of which should be fairly self-explanatory:
When you open a folder on the Stream Deck, the “Back” arrow is the top-left button, which is why I decided to place the folder there on the primary screen. I liked the idea of having the “Parent” folder item and the “Back” at the same location.
Botton-Right button
Also, you’ll notice that the bottom-right button is not Relay.fm specific. Instead it is a Stream Deck button to “Switch Profiles.”
As much as I love my Relay.fm Stream Deck profile, it’s not my default. When I use it, I want to then be able to switch back to my default profile with the press of a button.
My default profile also has a “Switch Profile” button in the same place. At the moment I only have two profiles, but if I make additional ones, I plan to use the bottom-right button as “Switch Profiles” on all them.
Download
Click on Relay.fm-2020-03-29.streamDeckProfile.zip to download.
Once unzipped, you can import it into your Stream Deck by double-clicking on it.
Don’t like how I have it set up? Once you have it, you can make any changes you’d like.
Tip: To give yourself some room to maneuver when changing things around, put 1 or 2 icons into the top-left “Relay.FM” folder and then move them back when you’re done.
