I’m trying to streamline my process for keeping track of letters of recommendation I write for students. I’m hoping to hear about other workflows or ideas you all might have. Any pointers or starting points are welcome.
Each year I write letters of rec for about 70 students. Each student asks me for multiple letters of rec. So it ends up being quite a bit of info to keep track of. To help me keep track, I have students fill out a Word handout that requires them to include specific information for each program. When a student returns their Word file to me, I create a project in Things and then manually add the student project, include each letter of rec as a task.
I’ve created a keyboard maestro shortcut that helps streamline some parts of the process, but I still need to input the video manually. In the gif below, you can see it in action. After I press okay, everything is entered automatically. I have half-second delays between each tab because it was buggy with shorter delays.
While this helps, I’m wondering how I can streamline the process. I’ve narrowed down the process to improving how I capture the info and converting the captures info to Things project/tasks.
Step 1. Capture the student information (Google Drive? Square space form? excel form?) I currently use a Word doc.
Step 2. Convert the information to something Things 3 can interpret with
- Project Name: - <degree type Master’s or PhD> in at
- Create a task for each letter of rec with
– (1) tag for Master’s degree or Ph.D. Degree
– (2) deadline
– (3) dropbox link to the student folder I create to keep all files they share with me
Ideas
I feel like step one might be streamlined if I could somehow act on the email form submitted by students through Squarespace or google drive. I imagine I might extract information from the email and format it into a taskpaper format, then… somehow import it into Things 3? Maybe through Drafts? Hmm. As you can see, there are some holes in my plan. Any thoughts?
