I’m having some very noticeable (to the point of affecting ability to do work) stuttering animations on my iPhone and iPad since installing the 17.6 betas (macrumors and reddit). Has anyone had improvement by upgrading to the iOS 18 betas or is it better to downgrade to the non-beta? I usually wait for the third public beta before upgrading, so I think I just answered my question.
I received a response to my Feedback within days. I never get a response, and this one was quick and supposedly solved the issue. So far, I’m not seeing any problems. ![]()
As a result of your feedback, there are software changes in the latest update, build 21G79, that have resolved this issue.
You can see the software build your device is running and check for the latest update by tapping on Settings > General > Software Update.
Has this issue been resolved after installing the latest update?
