I finally had a chance to test an iPad presentation configuration and confirm that it works.
I used my 12.9" M1 iPadPro as the presentation device, using the Apple USB-C Digital AV Multiport Adapter to connect to the presentation room’s HDMI connection to the projector.
I then set up my fairly old iPad Mini as the Keynote remote with its gen1 Apple pencil. The iPad Mini worked perfectly as the remote, smoothly advancing the slides as I walked around the room untethered by any cables. The Apple Pencil allowed me to annotate slides in real-time with no delay and no issues.
Neither device was plugged into power and I had plenty of battery for this 4-hour presentation.
This was a big win for me and I suspect that I will not buy another Mac laptop, as my main use for a laptop for the past few years has been for presentations.
My desktop is a 2019 iMac. I use my iPadPro every day, mostly for annotating PDFs in DevonThink and reading talk.macpowerusers.com
This is quite excellent news, as I often do sales presentations but don’t want to plug my company-supplied laptop into potentially data-scraping systems available at my destinations.
Are you building your presentations with Keynote on iPad as well?
Good to read this.
Something I haven’t seen mentioned by many other people: the iPad Mini 6 does better with external displays than any of the other pre-M1 iPads I’ve tested, due to the slightly different screen dimensions, which makes for an interesting conundrum— as in your example, the size of a Mini makes it great to have in hand as a remote…
As I’m finally getting back to a place where I may need to deliver more presentations, I’m curious about presenting using apps other than Keynote (e.g. iThoughts, Concepts, Defter, Endless Paper, etc). I used to use a cool little Miracast dongle that facilitated screen-mirroring without the need for a second full device; it would just plug directly into the HDMI port and present itself as an airplay receiver. Might see if I can pick another one of those up.
If you are using the pencil to mark up while presenting, does that mean you are presenting in editing mode rather than presenting mode?
@Aaron_Antcliff I build the presentations in Keynote on my Mac, mostly.
@Wrothnie I’m in Keynote Presentation mode. It’s one of the coolest things about using an iPad as the remote – you can switch into annotation mode and write on your slides in real-time using the Apple Pencil. The annotations are not persistent from presentation to presentation.
Ah! Of course! I had forgotten about that function. Thank you very much. I shall have to try it out.
