I spend a decent amount of time in TeamViewer for work. I like the set the resolution to match one of my external monitors and put TeamViewer in full screen mode. I also really like to use keyboard shortcuts to switch spaces. For example, Ctrl + Left Arrow will move left a space.
TeamViewer though… TeamViewer is capturing the key presses and it doesn’t make it back to macOS… I can’t find any documentation on a key combination to release the keyboard from TeamViewer without having to move the cursor over to another screen and click on another program or the desktop.
The shortcuts work if I disable “Send system key combinations” from the Action Bar menu in TeamViewer, but then a bunch of stuff in TeamViewer becomes more difficult. Has anyone else run into this or a similar problem that they have a solution for?
