Some great advice here. Virtually any Synology will work fine as a TM destination. I would most certainly go with a 2-drive model so that you have data redundancy. I think unless you are planning other server applications, a 4, 5 or more drive unit is overkill for you - the expense exceeds your benefit.
TM definitely has its warts. It is very reliable for me, until it isn’t, and like others, I then have to totally restart the backup - losing all previous versions / data. It’s a great first step, but I would never use TM as my only backup.
You are partway there with BackBlaze, but BB has some limitations as well. Firstly, unless you are paying for extended backup duration (you can pay extra for 1 year or unlimited time retention) your files are actually only preserved for 30 days. What that means if that as long as the file is on your local computer, it’s also on BB. But, if you were to change to delete a file, the old version is going from BB after 30 days. Thus, if you accidentally trashed something you needed but did not discover it for more than 30 days, you are out of luck if you are not paying for the extended file preservation option. Secondly, to restore files means either a download or waiting for BB to ship you a drive with your data. For a couple of files, a download is no big deal, but if you lose your entire drive and need to rebuild quickly, a local / onsite backup is the only way to get back up and running really fast. If you need that ability, you need something local.
My own process has multiple onsite and offsite steps.
Onsite:
- An SSD drive connected to my Mac Studio for TM
- A second TM destination on my Synology
- A daily clone of the Mac Studio to the Synology
Offsite:
- Backblaze on the Mac Studio (no extended file preservation, although I may add that)
- Arq to Wasabi on the Mac Studio
- iDrive from the Synology to the iDrive servers
I also have an M2 MBAir. All files on the Studio and Air are in sync’d folders using SynologyDrive to the Synology, and those shares are backed up via iDrive (along with other folders on the Synology that hold my media library and archives). Therefore, all files that are really important are always in sync between my two Macs and the Synology (actually there’s another folder for my wife files that via SynologyDrive always exists on her iMac and my Studio and Air as well). The laptop itself doesn’t have any backup running on it at present, since there are no files on it that are not mirrored via SynologyDrive.
There’s a lot of complexity and redundancy, but I have lost both files and drives in the past, but have been fortunate that I was, so far, always able to recover them through backups. Once I had to d/l 500GB from Google’s cold storage, which took days, but it worked. Once when my daughter had just arrived at graduate school over 1000 miles away, her MBAir died after her first day of classes. Thankfully, she had Are running. I ordered a new Air, fortunately in stock at the local BestBuy, she booted up at home, connected to the internet, downloaded Arq, connected to her archive, and by morning everything was restored. Worth the price for Arq software and the online storage!
One final note; The suggestion to connect an external drive to a USB (or TB) hub and use that for charging laptops is awesome. What a great way to ensure that an external drive, connected to the hub, is regularly connected to ensure a TM backup is done.
