System Data takes up a third of my local storage
Hi,
I’m using the latest official release of Tahoe. This morning I realized that 50 GB of free space on my hard drive had gone missing. When I checked under System Settings > Storage I noticed that System Data was claiming 300+ GB! Is this something to be concerned about? Does anyone know if it can be reclaimed? I understand that there are real use for System Data but this amount seems wrong.
Best regards,
Björn
In the article, it said:
  • Don’t expect macOS to free up any purgeable space for you.
Frankly, I’m surprise to read this. Isn’t this what a OS supposed to do?? Does it mean Apple expects user to run cryptic Terminal commands to clear up space that’s probably created by the OS?
For what it’s worth, after doing a Time Machine back up I have “the lost space” back more or less. However, the size of the system data category (the et cetera category according to the article) is still rather hefty. I would be interested in hearing the sizes of this category on other machines. It is 320 GB out of 1 TB for me.
That’s not how I would have worded that. It’s more that you cannot control when macOS will remove purgeable content to free up space. But if your amount of free space starts to get tight, macOS will release some or all of the purgeable content.
30GB of the 97GB of data stored on the 494GB HDD in my MBA
That’s about a third also. :+1:
System Data for me 347 GB, and I have a 1TB on my M1 Mac Mini
Ok, this looks very much like my numbers. Thanks!
check your time machine settings. if youre backing up hourly and Time Machine is only clearing out APFS snapshots monthly thats 720 APFS snapshots taking up space in the Data volume. I use a safe free App called Onyx almost daily… it can safely delete those accumulated snapshots… thereby freeing that space. snapshots are generally tiny but others can potentially be several Gb. honestly if you back up on any kind of regular basis manually… I dont believe you really need them…but Im just a long time user not a tech nerd :slight_smile:
