This isn’t something I’m actually planning on doing, but it did get me curious how it might work.
The goal is to remove myself from any large corporation as much as possible, limit my dependence on any piece of software, and reduce/eliminate anything stored on third-party servers. In my thought experiment I’m not aiming for 100% compliance. I don’t think that’s actually possible without fully dropping out of a lot of modern life.
This is for personal use – not trying to run a business. The requirements are I need a computer, a phone, music, and photography.
The end result is there should be very little tracking as possible and nothing I create should be able to be held “hostage” or be dependent on accessibility to a server outside of my control.
Since a phone and some online activity is involved you can’t completely avoid tracking or large corporations (I don’t know how you could reasonable avoid all websites hosted by Amazon or Google).
Hardware/OS
I don’t think I have a choice other than Linux. MacOS, Windows and Chrome are all too deeply embedded with the companies and I’d stay away from all of them. I’d prefer to use MacOS just cause I’m comfortable with it.
As for the hardware – I’d think a laptop would be most practical and it would need to be pretty durable. And of course I’d need to wipe it and install linux on it. I don’t know if there are any small, reliable laptop makers out there. I do like Apple’s hardware but they’d be one of the large corporations to avoid.
The laptop would mostly be run offline, only going online with a VPN.
For online access I don’t think there’s any reasonable way to avoid a large corporation and some degree of tracking. I’m taking it as a given I will need to go online at times. If I remove online access entirely this becomes a VERY different thought experiment.
Software
I think this is pretty straightforward. There are text or command line alternatives to most everything I do. If I go with Linux I could use Obsidian for a lot of what I would need. There are command line budget managers and Actual has a Linux version.
I could replace Adobe Lightroom with darktable.
I’m thinking going all in on Proton would probably the best way of managing email/passwords/vpn, though I’d need to look more at how their offline access works. I’m not sure how to avoid being dependent on another organization for email – my options would be limited here.
As for finances and shopping, I don’t think there’s any way to avoid some online access. I’m sure it’s possible to remain completely offline regarding banking and shopping, but there may be too much of a loss of practicality. It’s too bad Amazon is so ubiquitous and effective at delivering.
For backups, it would have to be local backups and driven offsite. An always on backup software like Backblaze wouldn’t cut it for numerous reasons.
For playing music, I think I’d have to go back to CDs, burned or physical disk. Any music service would be too online and have too much tracking. If I were to keep up with my current rate of music listening this could get very expensive buying CDs.
Phone
I’d probably drop the smart phone and just get the dumbest phone possible. There’s no way I could avoid tracking or leaving a digitial footpath with a phone and cellular connection. I’m sure there’s tons of basic functionality that I’ll lose but I’m sure very little of that is actually a necessity.
I spend free time/vacation time in deserts or traveling in rural areas. Some sort of emergency satellite signal would be needed, whether it’s embedded in the phone or another piece of equipment.
Photography
A phone camera is out as is any online sharing or storage. I’d have to just use my mirrorless camera and go with local storage on my computer of all images. Personally I don’t use any social media or photo sharing services so I’m not out anything here. I would miss using Lightroom, but there are enough alternatives that are non-destructive on the images – this would likely be the easiest part of this whole process.
Overview
My habits would have to drastically change. I spend way too much time digitally than I probably should, but a lot of it is where my interests lie. This would probably be the hardest part of all - changing my very ingrained habits and adjusting how I keep up with my interests.
There is of course somthing funny in this whole process…for the majority of my life this is how I lived by default. It’s amazing to think of how quickly so much of our day-to-day behavior has been completely modified.
In my thought experiment this is not a digital detox situation, or moving to some form of digital minimalism. It’s simply reducing how exposed I am, both in terms of my personal information/tracking and in terms of how susceptible I am to a particular service being shut down.
As for limiting use of large corporations – I don’t have a clear definition of what determines “large”. And it would be impossible to avoid entirely. Nor do I think in terms of this large corporation is “good” and therefore is ok to be used. The goal is to avoid all large corporations as much as possible. Think of this part as akin to shopping at locally owned stores vs chain stores when possible.
