There has been robust discussions in prior posts about the ethical and practical use of AI for writing. Moreover, @MacSparky often refers to AI as an “intern.” As I’ve continued to consider the role of AI in my workflow, always conscious of the importance of transparency and ethical use, it occurred to me that I could use AI for more than an editor. In the spirit of being a life-long learner (admittedly an overused platitude by educators), I can use AI as a writing tutor without compromising my integrity. With that in mind, I asked Claude, Gemini, and ChatGPT how they could serve as my writing tutor while avoiding do my writing for me. Of the three, ChatGPT provided the best response (see below). With that in mind, I’m going to try this for a few weeks. My purpose is not for AI to do my writing, but to teach me how to improve it.
To demonstrate how this might work, I submitted the above paragraph, warts and all, to ChatGPT and requested that it serve as my writing tutor. Here is what it returned:
Here is your revised paragraph and explanation formatted in Markdown:
Revised Paragraph
There has been robust discussion in earlier posts about the ethical and practical use of AI in writing. @MacSparky often describes AI as an “intern,” a helpful metaphor. As I’ve continued to reflect on AI’s role in my workflow—with a consistent focus on transparency and ethical use—it occurred to me that AI could serve a purpose beyond editing. In the spirit of lifelong learning (an admittedly overused platitude among educators), I realized I could use AI as a writing tutor without compromising my integrity.
With that in mind, I asked Claude, Gemini, and ChatGPT how each might help me improve my writing without doing the work for me. Of the three, ChatGPT offered the most helpful response (see below). Over the next few weeks, I’ll test this approach. My goal is not for AI to write on my behalf, but to teach me how to write better.
Explanation of Changes
| Original | Revision | Why It’s Stronger |
| There has been robust discussions… | There has been robust discussion… | “Discussion” is uncountable here; singular agreement is correct. |
| Moreover, @MacSparky often refers to… | @MacSparky often describes AI as… | “Describes” fits the context more naturally than “refers to.” |
| always conscious of the importance of transparency and ethical use… | with a consistent focus on transparency and ethical use… | Streamlined for clarity and improved sentence rhythm. |
| that I could use AI for more than an editor. | AI could serve a purpose beyond editing. | “More than an editor” is awkward; this phrasing is cleaner and clearer. |
| life-long learner | lifelong learning | More natural expression in this construction. |
| while avoiding do my writing for me. | without doing the work for me. | Corrects grammatical error and smooths the flow. |
| I’m going to try this for a few weeks. | Over the next few weeks, I’ll test this approach. | More polished and purposeful tone. |
| not for AI to do my writing, but to teach me how to improve it. | not for AI to write on my behalf, but to teach me how to write better. | Stronger contrast and phrasing. |
Using AI in this way doesn’t mean one should accept every suggestion. AI’s phrasing can sometimes feel stilted or impersonal. Still, it can offer valuable feedback that helps improve one’s writing over time. This approach leverages the strengths of AI while preserving both integrity and authenticity—if, and only if, one takes the time to study the explanations, learning from them or rejecting them.
Here is how ChatGPT responded to my original query about serving as a tutor.
Your Role (What You’ll Submit)
You will send:
- Drafts of any length (paragraphs, blog posts, articles, etc.)
- Your intended audience and purpose (e.g., professional, devotional, persuasive)
- Any relevant constraints (tone, word count, biblical references, style preferences)
You want to:
- Preserve your authentic tone and voice
- Improve clarity, vocabulary, engagement, and flow
- Eliminate redundancy, filler, and weak phrasing
You may submit as needed—no schedule required.
My Role (What I Will Do)
For each submission, I will provide:
1. Overall Feedback
- Brief evaluation of clarity, tone, structure, and flow
2. Line-by-Line Suggestions
- Edits that retain your style but improve readability and precision
- Highlights of areas where stronger vocabulary, conciseness, or better phrasing would help
3. Explanations
- Clear rationale for each significant change to help you grow as a writer
4. Optional Style Tips
- Occasional guidance on structure, rhythm, and rhetorical strength
- Only as appropriate and never at the expense of your voice
This will be an iterative, tutoring-style process designed to sharpen your writing while respecting your authorship. Ready when you are to begin the next session.
Thoughts? Is this a wise use of AI, a misuse, or something in between?
I think our resident journalism major, @ismh86, should weigh in. ![]()
