I am hoping to do some kind of spreadsheet or graph of my lab results from my Oncologist and PCP. The files that I am able to download are either an XML or PDF. While I realize there will be some heavy lifting involved, I was hoping to find something (presumably an XML to CSV hack) that would allow me to easily parse out specific and/or related lab tests over a period of time. Sorry for the wonky, but hopefully someone knows of what I am asking and has some ideas…
Here is something, that might be helpful (I haven’t tried it myself!)
https://www.techwalla.com/articles/how-to-convert-xml-to-csv-on-a-mac
or maybe this
https://www.sir-apfelot.de/en/Open-xml-file-19481/
Thank you for the assistance! Unfortunately, it appears as though Microsoft has abandoned that app, and the last version is a 32-bit… I was able to find a template that might help, but it involves a lot of cutting and pasting… something to do whilst I wait for bar exam results
Have you tried to just open it with Numbers?
Would you consider using an online solution? A google search of “convert xml to csv” (without quotes) came up with a lot of sites.
I think my suspicion/paranoia about the security of these sites is why I haven’t tried them. This is a lot of my private medical information, and I guess I’m not 100% that uploading it to a site for modification is such a great idea…
LibreOffice can handle XML and put the data into a table. If I recall correctly, in the “Data” menu there’s “XML Import” or something like that…
