Rose created an Applescript for me that would add a task in Omnifocus to pay someone in 30 days. This is triggered by the invoice being dropped into a certain folder. It works great! However I am now using the beta of OF3 on the mac.
How can I modify the following script so that rather than applying a context, it uses up to 3 tags?
THANK YOU!
Script -
set theDate to (current date) + (30 * days)
set fileName to item 1 of inputAttributes
tell application "OmniFocus 2"
tell front document
set theContext to first flattened tag where its name = "My Studio"
set theProject to first flattened project where its name = "SL Invoices to pay"
tell theProject to make new task with properties {name:("Pay " & fileName), defer date:{theDate}, deprecated context:theContext}
end tell
end tell
I just figured this out the other day. First you have to create the tags in Omnifocus. Assuming they exist, you then tell the project to create a new task with a single primary tag. Then you add each tag to the task. It looks like the following code:
tell application "OmniFocus"
tell front document
set thePrimaryTag to first flattened tag where its name = "My Studio"
set theTagList to {first tag where its name = "Tag1", first tag where its name = "Tag2", first tag where its name = "Tag3"}
tell theProject
set theTask to make new task with properties {name:("Pay " & fileName), defer date:theDate, primary tag:thePrimaryTag}
repeat with theTag in theTagList
add theTag to tags of theTask
end repeat
end tell
end tell
end tell
