Does anyone know of a USB C hub which can drive 4K UHD at 60 Hz and pass power to a MBP?
As far as I can tell the only options are for 30hz. Which means the only way to have a one cable external montor, power and hub (ie the usb c dream) is with a usb c monitor.
There are adapters out there that say they do it, but I don’t have any personal experience with them. None of them that I see have any other USB ports on them though, just the power passthrough port.
I (unintentionally) lied to you! It really does only do 4K@30Hz! When I traced the cable back from my TB dock, I must have made a mistake and followed the wrong one. The funny thing is that I could have sworn that when I was setting things up that I had to use the Apple connector to convert from USB-C to HDMI for the 4K monitor because it worked at 60Hz (and because I’d ordered the wrong cables).
My whole (desktop computing) life has been a lie for the past year!
I understand that desire. I opted to buy TB3 docks for my home and work office which give me that one-cable solution (for two monitors even), but they’re not exactly portable.
