Here’s a simple way I’m using Alfred to toggle Dark Mode on and off.
Create a new workflow with a keyword trigger e.g. “dark”.
Set up an action to run an Apple Script:
tell application "System Events"
tell appearance preferences
set dark mode to not dark mode
end tell
end tell
end alfred_script
Easy!
However, what I’d like to do is customise the script to switch the desktop background to the dark Mojave background if dark mode is enabled and then switch back to light, or dynamic when disabled.
Also happy to discover that Ulysses v.14’s option in View > Appearance > Match System works without any scripting on High Sierra - just use Alfred to switch modes and Ulysses will follow.
here’s an Applescript that will change the desktop to the light or dark version according to the Dark Mode setting. If you don’t want the desktop to change because you’re using the Dynamic, then juste remove that part in the script. You’re script acts as a toggle, so it would also work as is if you keep the dynamic desktop. I’m using it in Keyboard Maestro but I guess you trigger it the way you want. HTH.
set myMode to dark mode of appearance preferences
set desktopCount to count of desktops -- needed if more then 1 monitor
if myMode = false then
set dark mode of appearance preferences to true
repeat with desktopNumber from 1 to desktopCount
tell desktop desktopNumber
set picture to "/Library/Desktop Pictures/Mojave Night.jpg"
end tell
end repeat
else
set dark mode of appearance preferences to false
set picture to "/Library/Desktop Pictures/Mojave Day.jpg"
end tell
end repeat
end if
end tell
Thanks for the advice Jeff. However, I can’t seem to get this to work. I added it as a separate script after my initial script (the one that toggles dark mode). I also changed “Mojave Day” to “Mojave Dynamic” but am obviously doing something wrong:
on alfred_script(q)
end tell
end repeat
else
set picture to "/Library/Desktop Pictures/Mojave Dynamic.jpg"
end tell
end repeat
end if
end tell
end alfred_script
Also, is there any advantage using Keyboard Maestro over Alfred?
@paulminors you can’t change the name of the file that the script calls, the part where it says
set picture to “/Library/Desktop Pictures/Mojave Dynamic.jpg”
because it’s not a jpeg but a different kind of image. Did’t try, but if you put
set picture to “/Library/Desktop Pictures/Mojave.heic”
But, since the Dynamic is not the Dark version, then you either stick to it or you change between Light and Night.
As for Alfred vs Keyboard Maestro, it’s really up to you. I have it both in Launchbar and keyboard maestro. I’ve set a macro that is in my global palette and in the KM menu, and it just points to a script file. OR I can call the script from Launchbar, which ever I feel like at the moment.
Oh, and don’t put two script inside the same file! You can save my script in a file, and save your version in ANOTHER file, and then call which ever you want from Alfred, KM, or LB.
