Apologies if this has been discussed elsewhere. Feel free to direct me and we can delete this post.
I’m in my living room and remember I need to check something later in the day. My phone is on the coffee table. I thought it would be a simple task of saying “Hey Siri, remind me to tell my wife I love her at 5pm today.”
Also happens in the car. I don’t have Apple CarPlay as Elon doesn’t allow it in his Teslas.
But I need to unlock my iPhone first.
I have “Allow Siri When Locked” checked under Apple Intelligence & Siri.
And I have Siri checked under Face ID and Passcode settings.
What have I missed? Any help, or even confirmation it can’t work would be helpful.
Thanks guys. Yep, listen for Siri is on. I may take to an Apple store and they’ll show me something obvious I’ve missed most likely.
Sounds like it is supposed to work though, so that’s good.
When I looked at the Driving Focus mode I didn’t notice anything but then deleted that focus mode to see if that was the issue. Seems not.
To be honest, I probably did modify something to get it to work, but didn’t think I’d need to record those steps to retrace them. I certainly should have.
And, no, tried that and no dice.
Off to the Apple Store we go!
Thanks everyone. If Apple can fix it I’ll report back
Do you have a device profile from your work installed? Our old system didn’t permit siri when locked. i’d get the same message you’re getting. That restriction was lifted and removed from the policy and now it works fine.
