Hi.
Ever since I started using tags I have had this irritating problem with my main iMac.
For some context, I have:
- one iMac
- one iPad
- one iPhone
- one Synology NAS running DS Cloud
All running latest updates of everything constantly. All synced.
What happens is this:
All files stored in iCloud that are tagged shows 4 times in Finder, but all 4 “versions” have the same path. This only happens on my iMac (see screenshot)
Anybody else experiencing this? Luckily I don’t use tags that much so it’s not a practical problem, but it’s quite irritating.
Welcome!
I checked and I have a few files that show up twice. It is because I have the same file in two different directories. Maybe this is what you’re seeing.
Try turning on View | Show Path Bar so you can single-click on files and see where they are located.
Update: I just opened my NAS in locations, and now there are four copies of the files that I was seeing two copies of - two on my iMac, and copies of those two on the NAS.
Thank you.
It looks like the files that show up multiple times in Finder are located on different backup-disks and a folder called iCloud (Archive).
Problem was then easily solved by excluding these folders and disks from Spotlight.
Again, thank you
