Look Mom I can do UNIX.
The next task is how to find the Folders that have a lot of duplicates and consolidate them on the folder level, merging them to one folder.
Anybody have any suggestions on how to do that?
Prompt
Create a UNIX command to find every instance of given file name and then move every instance to a designated folder overwriting what is in there so that you just with one file?
ChatGPT
To find every instance of a given filename and then move each instance to a designated folder, effectively overwriting any existing file in the destination so that only the last found instance remains, you can use a combination of the find, xargs, and mv commands in UNIX or Linux. The approach slightly changes from the copy operation, as mv doesn’t need explicit instructions to overwrite files—by default, it will replace the destination file.
Here is how you can do it:
find /path/to/search -type f -name ‘filename.ext’ -exec mv -f {} /path/to/destination/ ;
Let’s break down the command:
• find /path/to/search instructs find to start searching from /path/to/search. You should replace /path/to/search with the actual directory you wish to start the search from. If you wish to search the entire filesystem, you can use /.
• -type f specifies that you are looking for files, not directories.
• -name 'filename.ext' tells find to look for files with the name filename.ext. Replace filename.ext with the actual file name you’re searching for. You can also use wildcards if needed.
• -exec mv -f {} /path/to/destination/ \; executes the mv command for each file found. The -f option forces mv to overwrite the target file without prompting. {} is replaced by the path of the current file found by find. /path/to/destination/ is the directory where you want to move the file. Make sure to replace /path/to/destination/ with your actual destination directory path.
This command will move each found file to the designated destination directory, overwriting any file with the same name that already exists there. Since each file found is moved sequentially, if multiple files with the same name exist in different locations, only the last one processed will remain in the destination directory.
