On Big Sur 11.2.3…
If I use Shift-Command-4 to take a screenshot, the crosshairs is stuck and will not move with my mouse. It works fine however on a different User Account on my Mac. It also works fine on the main user account if I use Shift-Command-5 (the entire screenshot app) rather than Shift-Command-4 (screenshot a selected area).
I checked my Keyboard/Shortcuts settings and chose Reset.
I rebooted my computer.
Other ideas?
Is there a .plist related to the Screenshots function that I can delete to fix it as is common with Apple software?
My sledgehammer approach to issues like this, when I cannot find the source of macOS misbehavior, is to boot into safe mode and run the maintenance set of clean-up utilities in Onyx.
FWIW, shift-command-5 can be configured to do a portion of the screen by moving the capture window around and resizing it. I usually use shift-command-5 by default because it offers much more control that the other screenshot options.
Good points - thank you
I am using shift-command-5 now and agree it has benefits - but the downside is that you need an extra mouse click to finalize every screenshot.
Ok let that be my worst problem
I found this article which lists a few things to try.
