Hello All,
I hope when you are reading this, you are doing well, healthy and things are working out for you. Well I want to try the iPad life for work but I need some guidance on apps that would help me. I will go thru of the programs I use on Windows laptop and see if we can get similar apps here.
On my daily job I use Outlook and M Office 365 so that I am ok. I also use Remote Desktop Manager to handle well multiple RDP that I need to connect to. At the moment can’t find a good app for this. Those Remote Desktop are all Windows.
In addition to this I manage around 100 Linux Boxes that I ssh to them. I use on Windows Mobaxterm (really good program) and have a list of all servers that I ssh and mobaxterm will even safe the password for me and the next time I login it doesn’t ask for password.
Basically that’s it that I use my laptop and that’s it. While writing this, not sure if I can create ssh public keys on my iPad and have that on the server so I do not need to put password will work also, but having a list where I can just select and even open multiple at the same time will work…
Hardware that I bought:
IPad Air 256 gb
Magic Keyboard
Pencil
Thank you for taking the time to read this and share your suggestion…
Luis
