What are these wire binder loop snap thingys called?
I assume these have a name, but I can’t find them on Amazon.
IMG_0937
Twelve South has a product like this called cable snap.
Cable tidies are probably the usual name :slight_smile:
The right search term to use on Amazon is “Cable Ties”.
I just placed an order recently for this item. Haven’t received it yet so can’t say if good or not,
Thanks, but this is a different animal.
I found these by searching for “cable snaps”.
Made 2 Go Snap IN Cord Organizer 3-Pack https://www.amazon.com/dp/B01N9F4KPN/ref=cm_sw_r_cp_api_H3.HBbK680SPB
Rose, that is so British!
Somehow completely missed your reply.
Thanks! ( Better late than never )
Yes, Made2Go Snap-In Cord Organizers. I bought these a few years ago, and they’re great. They work best (size-wise) for smaller cords / cables like earbud / earpod cords. As of April 2026 it appears they’re unavailable / out of stock. If you’d like to order a bulk amount of them, customized for your company, etc. it looks like there are several promotional materials companies which will produce them with your image on them though.
