Hi Everyone! I’m having some weird issues with my Wi-Fi. Lets get the tech stuff out of the way:
Computer: MacBook Pro,14-inch, 2023, M2 Pro Chip, 32GB RAM, Golden Gate 27.0 (Stable)
Router: TP-Link BE9700 Tri-Band Wi-Fi 7 Router
So first off, let me say that this issue is isolated to the computer mentioned above, so I do not think it is a router issue, but I’m open to opinions of why it may be. No other Macs, iPhones or other devices appear to exhibit these issues.
On the MacBook Pro mentioned above the Wi-Fi connection keeps cutting. To be clear, the Mac never indicates that the connection disconnects. I use iStat Menus and the indication that I can see when this occurs is the ping goes from sub-20ms to well over 100+ms, sometimes reaching a ping of 300ms. According to the Mac, I am utilizing my Wi-Fi 6E connection when connecting to my network. This issue causes the network connection to become stale and I cannot access internet or intranet.
Things I have tried:
Restarting the computer
Disabling AdGuard DNS (this is the only software that I can think of that would affect the network connection)
Disabling Private Relay
Disabling macOS’ firewall
Disabling “Private Wi-Fi Address” / MAC Masking
Resetting the DHCP lease
At this point I’m about to do a complete format and reinstallation of macOS 27. I did experience this issue on macOS 26. I’m starting to wonder if this is a hardware issue if the reformatting doesn’t fix it.
Does anyone have any other suggestions on how I can diagnose or fix this issue?
If you have more than one local computer, I would do a file transfer tests using the iperf 3 commandline utility.
One computer is the “sender” and one is the “receiver”. By sending a large test file over and over intermittant problems should be easier to see and help determine if an overall network problem or a hardware problem.
iper3 between local computers helps eliminate the Internet and localize the problem to only your own network, too.
In my original post, I should have mentioned. I was pinging the IP address 1.1.1.1; which is Cloudflare.
In my haste, I reformatted my Mac and the issue seems to be fixed. But thank you for your reply. Traceroute and iperf3 will be on my list if it reoccurs.
Glad it is working now. FYI, iPerf3 is not a built-in Mac command, but part of homebrew and other open source package managers or can be installed on its own with a shell script.
Since 8.8.8.8 keeps answering while 1.1.1.1 sometimes doesn’t, I wouldn’t read that as the Wi-Fi dropping. Next time it happens, ping the router, 8.8.8.8 and 1.1.1.1 at the same time, and try copying a file to another machine on your network. If the router and the local copy stay fine, the problem is past your network, not the Mac’s Wi-Fi, so another reinstall won’t help. Comparing Wi-Fi with Ethernet on the same Mac narrows it down further. I’d leave MTU alone unless a packet-size test points to it.
