Couldn’t decide whether to post this under HW or SW….
Is there a way to set the SD to automatically switch to the default profile if there isn’t a defined ‘smart profile’ for a specific app?
Thanks all!
Thanks all!
Mine works that way? I have app profiles and a base one. When I’m in an app that doesn’t have a profile, the SD shows me the base one. Do you have several non app specific profiles?
That’s how I remembered it working but after replacing the mobile app version with the XL it doesnt auto switch.
Maybe I actually don’t have any default profile - I’ll have a look. Thanks for helping me think this through
I don’t think there is a setting, but mine jumps back to the default profile when it comes off a smart profile, even if it was on a non-smart profile before it hit the smart profile, so I think it is default behaviour. On all non-smart profiles I added a “back-to-default” button in the left bottom to quickly go back
Yep. The default profile was not set. Thanks y’all
