Yeti Blue Microphone Doesn't Always Work With Dictation
I’m running Sonoma on a MacBook Pro ('21, M1 Pro). I use the Yeti Blue microphone for audio input when the MBPro is docked.
The Yeti Blue works flawlessly with Zoom and MS Teams but I have a problem when using dictation after the computer wakes up from sleep. Although System Settings shows that the mic is connected and working (input level shows mic is pick up sound), dictation simply doesn’t work. Strangely, putting on my AirPod Pros and dictating with tworks. Nothing seems to fix the problem other than a restart of the computer. It’s just for some reason, dictation won’t work with the Yeti after waking from sleep.
I’ve done some googling but can’t seem to find a solution.
I suspect the easiest thing to do is to just buy another mic but I want to avoid that as I’m really happy with my current setup.
Any suggestions?
Thanks!
Is the Yeti Blue USB 3?
Here are some recommendations:
https://talon.wiki/Resource%20Hub/Hardware/
I have a cheap Boya, works well
I assume you’re using an external monitor? If so, do you have a webcam with a built-in mic? I stopped using my Yeti Blue because my Logitech 920c webcam’s mic is just as good (!!), and it’s always plugged in when I dock my MacBook Pro.
I gave up trying to fix it. Now I use Superwhisper and I’ve had no problems.
