Zebu time tracking
I’m looking for an alternative to Toggl. I was finally ready to splurge on Harvest, but found out they’ve been acquired by Bending Spoons and unceremoniously jacking up customers’ prices with no warning — no thank you!
So I paid for a month of premium Toggl for reporting.
What I really want is something like the below image from Harvest’s marketing material:
You can set this up in Toggl, but it’s a little unwieldy, and the apps are truly terrible.
Has anybody tried Zebu? New to me. Looks simple and looks like it does what I want. I could just try the free trial, and I might, but I’m already started to get burned out on how much time this is taking (and boy oh boy, let me tell you how much joy the Toggl app is zapping out of my life).
The only thing Zebu is missing is a way for me to enter time without taking my hands off the keyboard. I want some kind of hotkey, then Todoist style shortcuts to start a timer in a project without actually navigating to the application. Then I want to be able to stop the timer with the same hotkey.
Ever time tracker says they do something like this, but none of them to do the natural language parsing thing, which is really the killer feature of that whole setup. The second you need to take your fingers off the keyboard, they blew it.
Ah, Bending Spoons, where once great apps go to die.
I use Timery with a few keyboard maestro macros to make starting stopping and editing timers easier. It’s not perfect, but it’s way better than standard Toggl track.
Would the API let you make a custom report?
The Toggl API? Maybe, but at what cost to my time and patience? I want something that just works out of the box.
Hi @snelly - I’m the author of Zebu! I came across this seeing how my search results were doing.
I’m also a freelancer who was on harvest for nearly 15 years - I’m fully on my Zebu for my tracking and invoicing and canceled my Harvest subscription after I got the insane pricing email I was expecting.
I really feel you’d appreciate Zebu, we have similar reporting and time forecasting (without paywalls), and the Mac app has configurable keyboard shortcuts for creating new timers and toggling etc. Zebu also supports a very comprehensive direct migration from Harvest.
It’s also only €5 a month with no special usage.
I’d really be happy if you gave my app a try and would be more than happy to answer any questions you might have - or to add any features that might make it a tool worthy of your time and energy :slight_smile:
Here’s a screenshot of our budget forecasting for projects:
Ah! This is the sort of screenshot I wanted to see on your website. I’m in. I’ll give it a whirl in the next month or two — makes more sense for my business to start tracking around the 1st of the month, and December is a short month so seems wasteful to do a 30 day trial when I’m only working 15-21 of those days…
Either way, yes. Love this. Thank you!
FYI, things that would be handy for me: iPhone app, iPad app (I could also just run the phone app on the iPad and be totally fine), and the ability to say a client gets X number of hours, and have the project monitoring across all the client’s projects count towards that tally.
Edit: I thought I should be a little clearer about that feature. Let’s say I have a client called Acme Co, and they’re on a $4,000 retainer that renews monthly, and my hourly rate is $100/hr. (All numbers hypothetical to make this mathematically easy.)
If I had a couple projects I was working on, like Acme Co Website, and Acme Co Annual Report, it would still be helpful to track those separately. If I spent 20 hours on each, I would be at the budget limit for that client for the month. If I spent 20 hours on one project and 21 on the other, I’d be over budget, and it’d be helpful to see that notification at the client level or project level.
Obviously this is a hard design problem to solve, but it’s how some of my business works, and most time trackers don’t account for it.
Ah yes, I’ve also encountered the same issue with some of my clients/projects and was thinking how to best solve it, so I have been building a feature for ‘budget grouping’ — for example, ‘Acme Co Retainer’ - then each project could be assigned to that recurring budget group. Then one can configure what to do with unused/rollover hours, if overage is billed or not etc…
I had the exact same issue where a budget notification wasn’t clear because the cumulative time was the important metric.
I’ll keep you posted, and it will definitely be ready before you decide to trial!
