I love a chat about folder and file naming conventions, let’s get nerdy
(One day my colleagues will appreciate the order I try to impose on their ridiculous file management - calling a file Super Important thing v5 the final version FOR REAL
is not an acceptable practice!)
I am a big fan of the principle of having somewhat similar folder structure across apps, at least at a top level, in order to handle one issue you’ve just highlighted, which is that some files are trapped in their own apps and can’t be brought to a central location. With a “universal” folder structure this doesn’t matter so much, because you only have to remember your general “map” of where things are, and it doesn’t matter which app you’re in. Don’t underestimate the mental overhead you eliminate just by standardising folder structure!
So, to answer your question, I have various areas of work responsibilities, and NotePlan is structured to reflect this to a degree. My work email (and Slack! and even Toggl Track!) and device-based folders follow the same structure (I don’t store many work files on my own system since that is not a good idea - I’m not self-employed - but there are a few files I just need all the time that are on my device). Within each top-level area folder, I tend to have subfolders for specific projects I’m working on. It is an exciting day when a piece of work gets promoted from a couple of “loose” files into a folder (for me, it’s a mental “promotion” of a small piece of work into an Official Project).
In NotePlan, I actually rarely need to create subfolders, because I try to keep one note for a project where reasonable. NotePlan captures pending tasks, meetings notes, thoughts I need to write down - and at a project level I don’t need to split this across multiple files. Sometimes a project is complicated though and needs its own folder with different notes for different parts.
I am also a big fan of numbering folders. This means I can standardise the order of the folders according to my own preference across software and reflects my own preferences. My structure is basically:
00. Ref (the important stuff I need on hand - can be permanent or temporary)
01. Pending (stuff I am working on right now that I want top)
02. Primary area of responsibility at work
...02.01. Project 1
...02.02. Project 2
...Small things not in a subfolder
03. Second area
04. Third area
05. Admin (always near the bottom as it's needed but not key to my work!)
06. HR stuff (files relating to HR things like payroll, holiday, etc.)
07. Tech stuff (files relating to support tickets, tricks for how to do things - I try to write down how I did something if I think I will need to do it again and it was hard to find the solution)
I break down my folder structure according to area because my job has defined areas of work and this makes sense to me. In a different job projects might be my top level structure instead. The key point is that all my personal work-related apps follow the same folder structure, which means I always know that my Primary Area is folder 02, no matter what where I am, or admin is always 05. I never have to wonder where to save something, as I just have to follow my rules. (This makes me sound a bit lame, but some rules are good!!)
