This was discussed briefly a couple of years ago.
I usually touch my desk’s leg to discharge, but my small vga display doesn’t like that. Keyboard sometimes hangs if I forget. I know these events can weaken components that can fail later.
Any suggestions other than:
humidifier
sprays work okay when my dress is clinging to my slip, but choke you to death if you fog a room.1
Thanks
1. Just kidding about the slip. No one wears slips anymore.
I touch the radiator in my office to discharge on static days. I usually grab my metal bottle opener on my keychain and touch that to it to avoid the pain (dry in CO - so shocks hurt).
You could, but that’s bad.
It’s like a small lightning strike.
Static electricity is weird too. It can sit in “pools” on your desk, and other strange things.
That’s why when I touch my desk leg, my external monitor freaks out.
Definitely not good. And I wouldn’t want to zap my iMac Pro.
Is there an electric outlet within easy reach? If wired correctly the cover screw of a 110 outlet is a ground. You could add a wrist strap or just tap it with a finger.
This started when I was forced to watch silly, scary videos at work, created by companies that sell anti-static products. Thing is, not once in my 20-odd career in I.T. did I ever have to replace a part due to static discharge. I even worked with a dude who claimed he had problems with static all the time, constantly shocking himself everywhere. Never saw a single part failure.
If you are experiencing a problem with your monitor, you should inspect your cabling and power outlets.
My takeaway is this: If you work in an electronics manufacturing environment, or a clean room, yeah, sure. Ground everything to the nth degree. Otherwise, you are being OCD about an infintesimally small risk.
I discharge myself here and there for one purpose only - to minimize any painful shock I might personally experience at my fingertips. Any other reason is overkill.
Well, I seem to have killed one of my drives.
It was in a metal external drive case sitting on the far end of the tray under my desk - the same tray I’ve been discharging my static to when I sit down.
Parts ordered yesterday for countermeasures, but a bit too late.
