I cut a dado in a piece of wood I liked at the same angle as the Analog and voilà.
You need to make a bunch of those and put them on Etsy. ![]()
That’s nice. Where do I order? ![]()
Is that enough room to slide up from the bottom, middle?
Juuuuust barely ![]()
Perfect distraction from writing! ![]()
Make and sell enough of them and you wouldn’t have to write. ![]()
That’s not a dado. It’s a groove!
Interesting – what would you say was different about a dado and a groove?
From
A dado is cut across, or perpendicular to, the grain and is thus differentiated from a groove which is cut with, or parallel to the grain.
Learned something new! Thanks!
I did the same thing years ago.
Then the iPad slimmed down and I never redid it!
For a modern iPad design, I might cut a notch in the middle to help with swiping.
