I’m using Exact Scan Pro with my trusty ScanSnap S1500M. It’s worked like a charm under Mojave and now Catalina. Far better than the Fujitsu s/w, lots of profiles, some I’ve setup to do OCR, others not. I love it - great tech support when I had a few questions when I started.
But I would never buy another Fujitsu scanner due to the way they treat their customers.
I have my device connected to dropbox. IX500. Of course everything scans to a particular folder. I know I don’t have anything going on after that but I never load the software. It just shows up in dropbox folder and I apply what I want.
I’ve been having ScanSnap Home problems; scanning to a network mount point would fail, and I couldn’t get changing the destination to stick.
I tried redownloading the software for a reinstall, but the installer told me no need, your software is already installed.
For awhile I used the phone version for scans, not looking forward to an afternoon of troubleshooting or uninstalling to reinstall. Your simple steps unstuck my scanner, thank you.
I noticed that. That site says that it Scansnap Manager is compatible with Catalina, but the installer crashes every time I run it. Scansnap Home works fine, though.
That is weird. I did not have any issues several weeks ago, when I installed it on my Mac Mini (Catalina). And if is still running fine today under Big Sur.
Buried in the installation instructions was a comment that any older version of Scansnap Manager should be uninstalled prior to installation of the new version. I don’t know if the same would apply to uninstalling Scansnap Home, but if you have installed Scansnap Home that would probably be a good idea.
You might try uninstalling older versions of Scansnap Manager that might be present and your current installation of Scansnap manager, re-booting the computer, then installing Scansnap Manager V7 L30 obtained from the link above. That procedure worked well for me.
I don’t care if it was only requiring 0.0001KB of ram. I do not wish to be forced to take extra steps to completely close your software and then still not know for 100% certainty if I actually did stop all related processes from running. Why is there no easy way to close this ScanSnap software from the provided UI??? It was frustrating enough that, after originally installing the ScanSnap software, I had to disable SIX different PC startup applications that were all under some kind of ScanSnap name. What the hell are the other five for???
I can’t help but think there must be SOME reason these kind of issues persist. And if what another person in this thread says is true, that after calls to their customer service and being told this would be “fixed” in updates and it has yet to be… there MUST be some reason that this flaw is still here years later as I am writing this in 2024.
Let me close your software without jumping through hoops. This is bad design.
I was one of those hesitating to switch to ScanSnap Home - because of the license and other issues. I got myself a shiny new Mac mini M4 Pro a few days ago and today we of course have passed October 31st, 2024.
I do have a backup of ScanSnap Manager, but I decided to give ScanSnap Home a try again. I am sold. The license issues are a thing of the past - as we all know - and the software just works (for me). The feature to name the file name generated from information gathered while scanning works surprisingly well. The scan quality is good. The menubar item is nice. What I am trying to say: if you still are using ScanSnap Manager, give ScanSnap Home a try. It has had a very bad start, but it has changed to the better.
I will not install ScanSnap Manager on my Macs any more.
