Hello all.
My trusty old car is getting a bit long in the tooth. I’m still more than happy with it, but might be making more trips with the kids in mine, so were looking for something a bit bigger/newer.
I commute 30m to work in the mornings, 30 back in the evenings, and other than this - don’t really spend much other time in the car.
One of the models I’m looking at, is a smaller hatchback, a 2018 release, more aimed at 1st time buyers, but perfectly acceptable for my type of driving/route to work.
It has Carplay.
The other, a sedan, (2017) is the typical reliable workhorse. Rental car companies like to use them. Nothing fancy, but bigger engine, and bigger boot/storage space, pretty-much bulletproof etc.
It doesn’t have Carplay, but its built-in touchscreen is perfectly fine. And it has a USB-in with Bluetooth.
My current car has neither of the above. So I drive to work with my airpods in, and listen to podcasts on Overcast. This works perfectly fine, since the Airpods still allow surprisingly much of the external noise in, to the point of being able to hear the engine, hooting etc.
To be clear, this is a vehicle that I will be using 90% of the time, so, with finances not being an issue, it really is my call. And in case it wasn’t also apparent, whereas I like cars (and car shows), the bug really hasn’t bitten me to the point that I feel anything much about my vehicles. It’s just something to get me from A to B.
The safe-reliable sedan should be the no-brainer. But the Carplay on the slightly smaller, newer model, has given me pause.
I’m mad, right? If I spent way more time in the car, then Carplay might be a consideration. But I don’t, so it shouldn’t be?
Would really appreciate some views on how ‘nice’ Carplay is? Is it more than a ‘meh’, and just a nice-to-have, as opposed to a ‘have-to-have’?
