I decided to start a new thread on this as I have a few issues, also linking my other post
The main issue I am facing is the random SSD reject but only due idle mode. I have an external SSD (Samsung EVO 1T) that is plugged into a Mac mini external HUB . The SSD is working perfecting fine under Big Sur. However, since upgraded to Monterey, I have experienced these errors, but only in idle mode
Try to eliminate the middle â plug the SSD directly into the Mac if possible and see if the ejection error reoccurs. Use Finder or Disk Utility when you actually want to eject the device. If a direct connection does not cause errors, then itâs possible that the hub is the culprit.
correct, it is eject, not reject, sorry for the typo
since it is an external SSD it is a bit hard to plug the SSD directly into the Mac without going through some sort of adaptor. Also this does not explain why it has been working fine in Big Sur and now only having issues when idle.
The error would not show up when I am using the Mac. I may have to get Apple support to look into this but they may say this is not their own product (HUB and SSD)
What do you mean âsome sort of adaptorâ? If youâre just using a regular USB / Thunderbolt drive cable plugged directly into the Macâs USB / Thunderbolt port, thatâs what @anon41602260 is almost certainly talking about.
The problem comes when youâre running through a USB hub or something along those lines.
This just happened to me with a bunch of USB-A connected drives. They spontaneously ejected. Iâve also been having major lag/stutter using a MX Master 3 connected via the unifying dongle. It seems thereâs some bugs in the USB-A system.
Iâm on a 2017 5k, so Iâm not sure if itâs an issue on Intel machines specifically.
@webwalrus , I just released that I was wrong in saying that the SSD is external, it is actually an âinternalâ SSD from Samsung. 860 EVO SATA 2.5" SSD 1TB
hence I need an adoptor of some sort. Sorry for the confusion
Ah, that makes sense. Yeah, thatâs a hub. Never seen one of those that you could install a hard drive in before.
SSDs connected to hubs historically have problems, off and on, with various versions of macOS. It has something to do with the Mac effectively going into a power-saving mode during sleep, which disconnects the hub, which disconnects the hard drive in (or attached to) the hub.
If you can find a dedicated external enclosure to try the drive in, that would be the next logical step in troubleshooting. See if a direct-connected drive also exhibits the same problem.
Apple will probably log a bug if you report it, but I wouldnât expect them to be able to do much about it.
@webwalrus thanks, I was think along similar lines too. Interested to know from @Christoski has similar issue, not sure this is a more common issue with Monterey, May have to wait a bit for more feedback to come out from the communities
Itâs not just Monterey. I was having a similar problem with Catalina and Big Sur. It just seems that for some reason you have been able to escape the issue. But, yes, it has to do with the way the Mac hibernates/sleeps/whatever-itâs-called-now. I think itâs specifically part of the power saving features built into the OS.
My recommendation is to turn sleep off and see what happens. As mentioned the hub may be powered down when it sleeps. I never allow my desktops to sleep but just have the d8splay turn off after a few minutes. Power usage is negligible.
