Macmini users what are you using for a Cam?
I’ve been happy with my M1 Macmini (for the most part) but I’ve been doing zoom calls using my iPad’s camera, while sharing my desktop using zoom on the Macmini. I would like to get a good camera that just works. I would prefer a USB camera as the BT is still flaky on the M1
Thanks
The Logitech C920 is a nice 1080p webcam. Their Brio is an even nicer 4K option.
Seconding the C920. Does the Brio give substantially better image quality (low light, focus, etc.) or does it just give 4K?
Check out this thread:
https://talk.macpowerusers.com/t/suggestion-for-webcam-to-mount-on-lg-monitor-while-using-m1-mbp/22952
As I don’t use it for work, I just picked up a cheap Chinese one from eBay which works well with my M1 mini. It was $15. Ended up using a Jawbone BT speaker for a mic, as the webcam one was really weak. The setup works great!
I got a 920, it’s not that good. Really bad dynamic range and you can get blown out skin tones. My solution was to set up a older mirrorless camera, it has worked really well and the image is soooo much better than the web cameras I’ve seen
I would expect so, given the size & cost of a mirrorless camera relative to a webcam. :slight_smile:
It was free … old camera that I didn’t use
