I’ve got a ‘problem’ that I’ve been trying to solve for some time, and would appreciate some advice on - even if that advice is it ain’t really a problem, move on!
Background - I use Obsidian for all sorts of things (notes, project management tracking, articles, resources etc.), nothing too taxing. I should add that although I like the app, I am always keen to find a native Mac/Apple solution, and keep dipping into stuff like Noteplan, Agenda, Notebooks, just in case they work for me, but have found some pinch points with each so far…
I use iCloud to store the Obsidian vault, and the vault (i.e. folders in iCloud) is structured around the PARA method. Everything goes in there - notes and all files (even if they’re not directly referred to within Obsidian, say via a note, link etc.) It’s my primary storage area and works well in it’s own right, available everywhere to all my devices.
This means my iCloud folder structure/Obsidian vault is quite large (it’s all related to work). That isn’t necessarily a problem until I come to use Obsidian on both the iPad and iPhone (fine with my MacBook Air). Because of the various files within the vault, Obsidian struggles when trying to index the iCloud folder, even crashing at times. If I manually wade through the various levels of folders within the Files app and try to ensure everything is downloaded, then eventually Obsidian will crank up and work.
While I know the ‘solution’ is to separate the bulk of ‘files’ from my vault into a separate set, it is very useful having everything together within the a folder-based PARA system.
I’ve also dabbled with using DevonThink as both an overall solution or an adjunct to Obsidian (using Ryan’s excellent plugin) - the issue Ive found with that is DT’s slight unreliability with indexing cloud-based stuff (something I think I’m right in saying they generally advise against).
I could use DT with a folder outside iCloud, but then Obsidian mobile won’t work. I could use Obsidian sync, but then I don’t have the cloud-based folder structure available to all devices/apps - it’s ‘exclusive’ to Obsidian.
Any thoughts or ideas welcome ![]()
