Hey Y’all, I’m looking for an app that I can use for Quick Note capturing and document lookup. Preferably uses iCloud or Dropbox
1. Quick Note capturing: Basically, the app is fast, and can be used to store quick notes. These notes might stay there for a while, but it’s not a knowledge management system. Mostly things I want to look up quickly. Like serial numbers, some snippets of text, food receipts, etc.
2. Document Lookup: It can store images/PDFs of documents and I can refer back to them. These docs are mostly things I might need to refer quickly, like driving license, bank account number, etc. I don’t intend of using this as a document cabinet. Maybe max of 100 docs.
3. Searchable: The notes are searchable/indexed. Like Apple Notes, which show up in spotlight search on iOS and Mac so I don’t have to open the app and search for it
ATM, I’m using Bear Notes for it (quick/searchable/uses iCloud), but want to minimize the subscriptions I have. Apple Notes is another good one, but the lack of export options and formatting stops me.
Can you suggest a few apps that might suit my needs?
- Drafts? Seems Drafts doesn’t support images/PDFs
- Obsidian?
