Recs for portable MagSafe chargers?
Looking at this one now:
https://www.amazon.com/dp/B0B973JZ3X/
  • 10,000mAh
  • 18w
  • % charge display (which I really like)
What do you think? Are there better options out there for the money?
Thanks in advance!
I’m always a little cautious about battery packs and charging cables. I wouldn’t buy either from a company which is not well known. Anker would be my provider of choice and if you want something like this, Apple’s Magsafe battery pack would be on my list.
I just bought an Anker battery pack with USB C and USB A for £40 so I can use it to charge anything.
https://www.amazon.co.uk/Anker-PowerCore-Essential-External-Compatible/dp/B08LG2X98F/ref=sr_1_17?crid=252X1FE4L8320&keywords=Anker&qid=1683008136&sprefix=anker%2Caps%2C106&sr=8-17
Thanks, I appreciate that. I gave this one a try, I really like the display on it, but it didn’t charge as fast as I’d hoped so I’m returning it and will look at some Anker products.
Anker has a MagSafe battery charger that I saw somebody using while traveling. It seemed quite useful while I was fumbling around with cables
Anker 633 Magnetic Battery (MagGo), 10,000mAh Foldable Wireless Portable Charger, 20W USB-C Power Delivery for iPhone 14/14 Pro / 14 Pro Max, iPhone 13/12 Series. (Black) https://a.co/d/iK2kVnu
