I currently have all important files in the Dropbox folder on my iMac, backed up to Backblaze cloud.
I wish to replicate this with iCloud Drive by placing all important files in the iCloud Drive folder on my iMac and backing up these files to Backblaze (or alternative location?).
(n.b. I don’t mind not being able to share folders - for that I will just continue to use Dropbox).
If I leave ‘Optimise Mac storage’ unchecked will this definitely leave all files on my IMac and allow me to fully and reliably backup iCloud drive on my iMac to Backblaze?
Contrary to Steve Jobs quote about the Cloud being the truth, I wish my iMac to be the truth.
It seems the answer is yes this will be fine, as long as optimisation is turned off. I think I was confused as people seem to use ‘iCloud’ to refer to both ‘iCloud Drive’ and ‘iCloud’…
What information are you hoping to have reported back?
I made this transition a little over a year ago – almost everything moved from Dropbox to iCloud Drive (some things live in Dropbox because that’s where collaborators work, or because I need to share a folder), optimize storage OFF.
Backed up to Time Machine, CCC, and BackBlaze. With optimize storage OFF anything in iCloud Drive remains on the local disk and available for backing up.
It’s really been friction free. While once in a blue moon I miss the versioning that Dropbox offers, it’s so very rare that I need that feature and the day-to-day seamlessness of the integration outweighs the periodic lack of versioning.
Cool. Mostly I’m concerned about relative sync speed. I’ll be keeping optimize turned off, with backup to BackBlaze. My understanding is that BackBlaze checksums and I won’t need to re-upload it all if I just move it around my local HD.
I do have a few important text files (TaskPaper docs) where Dropbox versioning has saved my skin but I think I can keep these in DB and be well under the free limit.
Does iCloud Drive allow full text search on iOS devices?
Sync speed with iCloud Drive seems comparable to Dropbox. At least, if there is any difference one way or another, it hasn’t impacted me and my use. Mostly I’m storing PDFs and smaller text documents. It’s been fairly smooth sailing.
Are you sure? When I search in Files app it only seems to hit based on file names, not content.
I’ve been looking at options and it seems Google Drive and OneDrive are the only major cloud services that allow full-text search, and only in their own apps. DB does but at the $200/yr level which is not appealing.
I have never found a way to do full text searches on IOS. Of course, it could just be a case of “I’m doing it wrong”.
When searching for a replacement for Evernote, I uploaded several types of files (txt,pdf,rtf, etc.) to both iCloud & Google Drive. Almost immediately after syncing I was able to find files on Google drive (using their app) by searching for keywords that appeared within the document, but not in the filename. I was never able to locate them on iCloud by searching for the contents of a file (in Files or IOS Spotlight), even days after they were uploaded.
Recently I was searching for a document containing the name of a friend, the Google Drive app prompted me with a “Did you mean:” suggestion when I mistyped his last name. I’ve been very pleased with G Drive.
You’re right, actually. I guess between effective file naming for searches in the files app and DEVONthink To Go, which DOES do content search I never failed, and forgot that Files doesn’t search contents!
My wife and I made the move about 6 months ago from separate Dropbox accounts to iCloud 2 Tb with family sharing. I moved to iCloud Photo Library at the same time (from Lightroom and files & folders).
I haven’t seen any measurable sync speed or other side effects (but I haven’t measured either).
The 2 key functionalities I really miss are folder sharing and the option to choose the location of the root folder (I use a MacMini as a server with DropBox running on it too so that I had a second physical copy; due to the migration, I couldn’t keep the sync files on an external drive and I had to upgrade the internal 128 Gb SSD to 1 Tb). There is no selective folder synching either but I don’t miss that.
Key upside (other that the cost in our case) is the the simplicity: iCloud takes care of everything across all devices, no need for 3rd party apps.
I wouldn’t go back.
Backblaze will be able to back-up your all your iCloud content if “Optimize Mac storage” is turned off. I’ve been using Backblaze even before I had iCloud Drive. When iCloud Drive launched, I moved all my working documents/files so it would all synch to my work MacBook Pro. So if I needed to work on any files, I don’t need to take home my office Mac and work on my home Mac instead.
Just don’t treat your iCloud Drive as a backup though. I’d still recommend having another backup solution for all your files. I usually move files that are for archiving away from iCloud when I no longer need instant access on it. So backing up a separate back-up drive to backblaze works. If I needed that file, I can just get it thru backblaze when I don’t have access with my hard drive.
Yes, good point. This is how I have been working on Dropbox at the moment.
One of the things that appeals to me about iCloud is cross-platform tag syncing, but unfortunately Backblaze doesn’t preserve tags on restore. Dropbox syncs them between Macs but not to iOS.
So you are saying to “uncheck”, Optimize Mac Storage, resulting in it being turned off? Outcome, Everything will be back up on Backblaze? But if you leave it turned on, what is the outcome?
If you have it turned on/checked (meaning Optimized Mac Storage is selected), it will only back up files that are stored locally on your hard drive. Files that are optimized by the setting turned on will not be backed up since those files are not stored locally on your hard drive.
