I am intrigued. The power difference between GB and DK is not existent and not an issue. I you look at the “charger”, it’s probably multi-voltage (110V-220V).
When I said “watt/power is irrelevant”, I meant the socket side. Your wall outlet doesn’t care if it’s 10 or 40W. That only is interesting if you get near the breaker limit (power-tools).
I don’t own a HomePod. But, looking at other devices, and similar problems I saw:
maybe completely resetting/restoring the HomePod (CPU/memory load high due to whatever issue?). I once had an iPhone that was “too warm” and draining battery. Nuked it, problem solved.
In the UK most people knew how to wire a plug. I guess few do now. I wonder if the same applies in Denmark (which shares plug format with many European countries).
But the voltage - 240V - and the frequency - 50Hz - are common between the UK and mainland Europe. You shouldn’t need a transformer.
It was at some point in June July after the 14.6 update it was really hot. Like faulty software made it stuck. And then using the HomePod as an output for the new Apple TV 4K really made it hot even when not in use. So I turned that off
I can’t replace it as they don’t sell them here and the apple repair won’t even touch it. I have to return it to the shop in the uk that I bought it at.
I still occasionally pull the plug on it if it put my hand there and it’s not in use and it’s too hot then I pull the plug and leave it.
But I’m sure apple will bring some kind of improved HomePod in the new year. So I’ll wait it out and get that one
a travel adapter should be more than adequate to do the plug conversion and be of no impact on the issue.
please google Homepod running hot. there is a lot written about it out there, however not many solutions.
I had one HomePod running hot consistently and in the end it lost all of its Bass. Only plays Treble and Mids, but strangely enough no longer runs hot. 14 months old so out of warranty and Apple doesn’t repair these things. They replace if you pay.
There is no wired connection. The HomePod 2018 and Apple TV4K stand next to each other. But I no longer use the HomePod as sound out for my Apple TV. I suspect that made it really hot. But perhaps there is some configuration behind it that I’m not aware of in which the two communicate and wirelessly and that can perhaps make the HomePod hot some way
I did a lot of work on this in July and august. And was in touch with a senior Apple support person who would pass it on to the engineers and get back to me but he never did…
my experience is that stand-alone it works well and doesn’t get hot. A.s.a. connected, either in stereo pair or to an AppleTV it runs hot. It seems that it wants a constant connection verification and doesn’t switch off or sleep to allow for instant connection.
I have 2 on my desk and only connect them to my AppleTV or as a stereo pair when I use them for that purpose, otherwise, I keep them as stand-alone devices.
