I can’t talk to Beta 3, but it is a beta so I’d expect there to be some volatility in how well it works. Beta 4 may fix any issues you see…or maybe beta 5. Either way, submit feedback to Apple.
And please tell me you’re not running this on a mission critical system.
Nope. Just my secondary computer. But it is where I run Scansnap. So I’ll just batch OCR them for now, assuming that’s any faster than the usually zippy inline OCR during a scan.
I believe that ScanSnap is 32-bit. Perhaps this type of behavior is what Apple has been warning us about re: 32-bit apps not functioning properly in the future?
I believe that the 32-bit restriction does not happen until the MacOS version after Mojave. Mojave just warns you and asks you to notify the developer. Who will just :::LOVE::: all those notifications, LOL.
I was asking in case there are other Scansnap users here that are on Mojave beta. That way, I can debug knowing whether it’s a local issue for me or there are others experiencing the same bug.
I bet Scansnap Ninja @MacSparky has an instance of Mojave running. Just sayin, David…
I wonder if this tweet from SuperDuper’s Dave Nanian may offer a clue: This might be related to the tighter permissions and security in Mojave that an app could address directly after an update, but may need a workaround until.
If you’re trying to use SuperDuper! 3.1.7 with the current Mojave public beta, please add us to
System Preferences > Security & Privacy > Privacy > Application Data
That should allow us to work.
I plan to mess around with it when I’m back home later this week.
I am running the Mojave public beta v3, and ran into the same problem yesterday. The OCR takes forever. Will try the workaround mentioned, and let you know if it helps at all.
I’ve heard that the public beta has an agreement as well. Of course that doesn’t mean that anyone is actually taking this seriously.
Here’s the FAQ mentioning the confidentiality agreement for the public beta:
Is the public beta software confidential?
Yes, the public beta software is Apple confidential information. Don’t install the public beta software on any systems you don’t directly control or that you share with others. Don’t blog, post screen shots, tweet, or publicly post information about the public beta software, and don’t discuss the public beta software with or demonstrate it to others who are not in the Apple Beta Software Program. If Apple has publicly disclosed technical information about the public beta software, it is no longer considered confidential.
Just checking back to see how the latest beta is playing with ScanSnap software. Any new feedback? I love my Fujitsu, but is it just me or is there support of the software waning? Last time I checked it was still 32 bit as well, although my understanding is that this is still OK with Mojave.
Another voice of concern regarding ScanSnap software support for macOS.
Back in January of 2017 I contacted Apple tech support and Fujitsu tech support regarding problems with PDF files created by the ScanSnap, associated with macOS Sierra 10.12.3 release. Among other problems, the OCR layer was broken - no files could be created with OCR support. Later, in Nov 2017, with macOS High Sierra, PDF files created with the ScanSnap were corrupted by out-of-order pages. I have been told that these problems were due to Apple’s new implementation of PDFkit, the macOS software that supports PDF files. These problems were resolved eventually, but a few bugs persist even today.
A Fujitsu tech support rep, after some delay, advised me (by email) to download and install version 6.3 of the Fujitsu software, designed for the iX500 model. My scanner is the S1500M model, for which the latest software support posted on the Fujitsu website is version 3.2, apparently from several years ago.
This, along with comments from others above, makes me concerned about ongoing support for the ScanSnap line for the Mac. If macOS Mojave “breaks” the Fujitsu drivers again, I will have to choose between keeping the Fujitsu scanner and updating to macOS Mojave.
Someone, elsewhere in this forum, suggested using the scanning software VueScan with the ScanSnap scanner. Does anyone have experience with this?
I’m using Vuescan with my old Epson Perfection 4870 Photo flatbed scanner and still running ScanSnap with my S510M. I can do a vew quick tests to see if I can run VueScan with the ScanSnap scanner later today and report back.
Edit
Decided it would take only a few minutes so tested it:
VueScan works well with teh scanner, recognized it and all its features upon startup with no problems. However it does not appear to connect to the OCR options at all. Since OCR on the ScanSnap is separate SW I am not surprised. I never use OCR on scanned documents so that wouldn’t bother me but YMMV. I think you can work on getting the OCR to work outside the actual scanning but I don’t know how.
