For the past week I’ve been having connectivity issues multiple times a day with M3 MBP on WiFi. 3-4 times a day my Mac decides it doesn’t have an internet connection even though it’s connected to WiFi.
Don’t think it’s the router - no other device in the house loses an internet connection my MBP does
DHCP Lease - I.E. the IP address of my Mac being assigned to something else. This morning it happened twice in one hour since DHCP leases are never that short
Reboot my MBP - I have twice in the past few days
Location - I’ve had happen in my office and in the kitchen. Neither is more 20ft from the router
Or a microwave oven, a notorious source of wifi interference. Did a family member heat up a cup of coffee when you experienced the problem? Another possibility would be a USB 3.0-connected device such as a portable HDD or SSD connected to your MBP.
@shandy wow every knob, dial and switch under the sun. Cool. I could spend weeks lost inside this maze.
@Arthur Thanks USB devices connected - at my desk a OWC Thunderbolt dock and from it my monitor. However, I’ve had this problem away from desk as well.
@jec0047 Thanks - just to muddy issues further, I hardwired my computer this morning with an ethernet cable and then had another outage in the early afternoon.
Running zoom all day to facilitate a workshop was a good way of surfacing this strange strange issue.
If you have multiple active connections, your computer tries the one at the top of the list first, then tries the others in descending order.
So it is possible, albeit unlikely, that your Mac could be accessing the wifi network. You can eliminate that possibility by turning the wifi off. It certainly couldn’t hurt.
@MacExpert My MBP is on wireless 99% of the time. I dragged an ethernet cable around the house on Monday to see if a wired connection would fix. No such luck. The problem is definitely happens on wireless, it also happened once when wired. Since the cable is draped over two floors I can’t afford to leave it around the house for days on end.
What I was looking for was whether your gateway or router logs network events. Unfortunately documentation for that device seems pretty scarce. Also unfortunately, complaints of wifi drop-outs seem to be rather common with that device.
If you can locate a logging function on the gateway you might find something to point you in the right direction. Otherwise a tech support call/visit may be in your future.
How about 0.5 – Bell (the ISP) has no idea what the problem is. So they’re dispatching a new modem in an attempt to avoid dealing with the problem. As to the upgrade, I honestly can’t figure how I will even notice the difference.
If the new modem is better - I win. If not I will hit the log files again.
When I saw the pppo:TR69, that’s clearly on their side,
SO, yes replace the modem (so they can successfully run TR-069 stuff), and when You said “you won an
upgraded connection…” I thought that they had maxed you out as compensation for their errors
this happened to me with a similar incident, and my speed was upgraded at no charge and I wondered if it was an industry thing?
